Hi. I have a System3 DE filter and have been having some problems with it.
First, I'm getting more filter medium in the pool than in the past and it is also clogging the pool cleaner inlet screen within a day or so and I have to spray it out regularly for the pool cleaner to function right.
Second, the PSI is building pressure very fast. I backflushed the system and pressure returned to normal at about 18 psi but 3 days later it was up to 25 psi and my waterfall features had a significantly reduced flow. I backflushed again on Monday and this time put less DE than I did last time, in case I put too much in last time and that was the issue. Again, PSI went back to 18 but 3 days later I am now at about 21 psi. I used to only have to backflush a couple times a season so there is something really different here. I am getting ready to go on a trip and am concerned about leaving it this way for my wife while gone.
I have never taken the filter apart and manually cleaned it. Could that be my problem? At what point should I invest in a new filter?
Thanks Steve
Thanks Steve
