I have been battling high CYA, ph bounce and chlorine issues all summer. I keep getting clumps of brown algae on the ramp to the deep end and along seams. I treat by shocking, adding yellow out and vacuuming to waste. I had stopped using chlorine tabs and am using only CAL-HYPO and liquid chlorine. I had the CYA down to about 60 and tried tablets again in the floater again. I put it in and the next day I found it on the bottom of the pool with the top off. Not sure what happened, but when I tested the water that day, the CYA was 100. Could the CYA jump up that much overnight?? I'm wondering if I'm not reading the test correctly. Do I read it when I can no longer see the black dot at all? The test says "until the black dot just disappears". Thanks in advance!!
