I'm not a pool guy as such, but I maintain a few under a Property Management company, mainly because I am at the property doing the gardens...The problem I often encounter here is high Cya readings. I'm using the Mareva test strips for Free chlorine, Total chlorine, Alkalinity, Ph, Total hardness & Cya.The Cya reading is often in the 'Purple' zone, making it between 150 & 250ppm, according to the bottle.
The chlorine tablets are a medium brand of Trichlore, and the same for when I use shock.
Should I start introducing non-stabilized chlorine tablets for maintenance, maybe 50/50?? Is that chemically dangerous, if I did that? And would that have an effect on the Cya?
I've had to remove a third of the water from one pool twice this season....not ideal!!
