- Oct 16, 2019
- 552
- Plaster
- Hayward Aqua Rite Pro (T-15)
When reading CYA, I thought it might help if I took photos of the vial. In the photos below, the one on the left is using the 50ppm standard solution for TF TestKits. The photo on the right shows my pool reading that day (I had the vial filled to the 70 line).
As you can see, the 50ppm solution filled to the 50 line on the vial clearly still shows the black dot, while my pool water at 70 shows it almost gone... which leads me to believe I'm probably actually at 80, note 70.
Thoughts on using pics as a standard for more accurate readings? And thoughts as to why the 50 reading is still showing the dot pretty clearly?
CYA: 50 CYA: 70-80? (Pool)
