BobbyR:
No, I do not see any grey fluff on the steps or ladder. Only during pollen season, after the filter was shut off did I see in the morning some stuff on the water surface (hard to tell). Each morning, around 6:30 a.m. as I stare at the water, there is nothing on the surface besides a few bugs floating around.
My guess is that the liquid chlorine has degraded. The white boxes were purchased 1 week after I opened the pool. The brown box was purchased approximately 30 days later. I stocked up for the whole summer. Chem Geek states that after 231 days, 12.5% will degrade to about half of its life. A 25% margin error would mean my bleach has degraded to 9.375%, which could mean that the old bleach was sitting around for some time. This could be a possible cause along with having more gallons then what I was told. With 14,700 gallons and to increase your FC from 4 to 7 with a concentration of 9.35%, you would need exactly 60 oz. The numbers make sense, but is this the answer?
I opened the pool on Sunday, April 26th, 2015 and tested the water after 2 hours of running time (12 p.m.). The FC reading was 2. Added 1 gallon of 12.5% that was purchased at Leslie’s nearby. This would have raised my FC to 9.5 on that day. Monday, the 27th, the next morning I tested 8.5 FC, 0 CC. The temperatures were 68, 65, 68, and 75, for the 4 days that this testing started. I added no more liquid chlorine and tested on Thursday (day 4) and had a reading of 5 and CC of 0. The next day I was at 4 and the temperature was 56 degrees on that day. Then I started adding approximately 30 oz. for the next few days and I even lowered the amount to 15 oz. for about 5 more days. After this, I started adding 60 oz. of 12.5%.
As you can see, the chlorine demand was very low in the beginning. When pollen was falling from the sky, and heavy for that month, I had to increase the amount of liquid chlorine to about 60 oz. daily. I am following the TFPC method protocol to a T. This evening, I will start the OCLT test to determine if all 3 areas are passed. I will even test the water before I leave today (around 12:30 p.m.), then when I return at around 6 p.m. and then at around 10 p.m. And yes, I have plenty of reagent's. The drops must be good because they only have been around for 12 months.
