Hi All
I live in the Northeast and we’ve got a ton of rain this summer. I’ve actually had to pump water out of the pool on two occasions. Probably a total of 6-7 inches. I tested my CYA this morning and it’s down to about 40. Ideally I should be at 60 correct? I’m assuming the water dilution because of the rain caused the drop. Should I add more CYA? I’m a little worried that I’ll end up adding too much which is a bigger problem then haveing two little in my opinion.
Thanks for help
Thanks for help
