So over the winter i had to drain my pool down twice (between closing and the 2 drainings, as well as the vacuum of leaves probably took out close to 4 feet). As a result my chlorine is flying out and my CYA test filled up the cylinder today and was still showing a visible black dot. I assume i am at less than 10.
I generally add liquid chlorine but i do have some pucks left over from the previous owner (about 2 years old now).
1. Can i raise the CYA with the pucks?
2. will 2 year old pucks work?
3. The pool is about 27,000 gallons, so how many pucks would i need?
4. If pucks are not the way to go, what is the recommended dry stabilizer (or is wet better)? DO i get at home depot/lowes or amazon?
Thannks all!
Thannks all!
