I'm opening my pool late this season - uncovered it last night and started a SLAM this morning.
When I closed up last year, CYA was at 44. I drained 15% of water last fall, and added it back last night. By my calculations, CYA should be around 37, but when I measure, I'm getting LESS THAN 30 (water is nearly clear and the black spot doesn't even look dim at a measurement of 30!). FC is dropping like a rock in bright sunlight, which is consistent with very low CYA; a few hours ago I had FC up to 20 - just now it was 4.
Oh, and my CYA reagent is date stamped good through 12/2018, and was kept in the room temperature basement all winter.
I am under the impression that nothing reduces CYA aside from replacing water. The majority of my water has not been replaced. What gives?
-Pete
Just west of Philadelphia, PA
-Pete
