Re: Getting on the right track: calcium high, monopersulface residual reading, and m
Yes, with circulation you should be able to test within a half hour of adding chlorine to the pool. With not great circulation, you could wait an hour instead.
Non-chlorine shock (MPS) will not go away on its own unless there is something to oxidize. If you severely overdosed, it will stick around for quite some time.
MPS at usual dosages will not directly react with DPD so does not measure as FC in that test but it definitely reacts with the potassium iodide in the CC test. However, if you are using a FAS-DPD test (as with the TF-100) then if there is any chlorine at all then your FAS drops will also end up measuring the MPS. This is the pink that keeps returning effect that you are seeing. If you were to do the FC test as normal, meaning the clear needs to remain clear for a bit of time, then you'd end up (slowly) measuring all the MPS as FC.
In your case with probably rather high MPS levels, the MPS itself can also react some with the DPD to show up as FC even if no chlorine is present. Basically, having a lot of MPS in the water wrecks havoc with testing.
The Taylor K-2042 kit has an MPS interference remover that may let you test your pool yourself in spite of the MPS levels in it. I suggest you get that so that you can do better testing yourself.
It may be possible to get rid of the MPS by using a reducing agent to remove all oxidizers from the pool, but of course that would put your pool at risk for developing algae during that period of time. Hydrogen peroxide may be able to be used for this purpose (such as in Baquacil Oxidizer -- NOT CDX), but I don't know how quickly the MPS and hydrogen peroxide react with each other (I've asked Dupont, but they don't know). So this technique would be experimental -- probably only worth it if you were truly desperate to get rid of the MPS in your water. I think you should get the K-2042 kit and eventually the MPS will decline over time though it could take a while.
