Problem: High salt levels in pool.
As this thread testifies, we went through many challenges with our pool this year, but with the support of TFP, we have gotten the metrics under control. One odd thing that I mentioned before, we thought the pool tasted salty. When I went to pick up more liquid chlorine from the pool store today, I had the water tested and the metrics are in line with my testing using the TF-1000 kit. When I mentioned the salty taste, the assistant at the pool store used two tests used on salt water pools and both showed salt concentrations of 3600 - 3800, which is high for salt water pools (the equivalent of 500 lbs of salt?). No one can explain where this salt came from, but their suspicions are the large amount of liquid chlorine used during the spring. Another note: It seems that the salt taste of the water is very noticeable when the sun is out, and after dark there is hardly any taste at all. Some chemical reaction going on?
Our metrics are (from TF-1000 test kit)
pH = 7.5
Alkalinity = 80
Calcium Hardness = 400
Free chlorine = 5.0 ( we add liquid chlorine every night to bring it up to 7 to withstand the burnoff from the pool being in the pool all day)
CC = 0
CYA approx. 40
Water temp: 72 in the morning, 76 by 5 p.m.
We were hoping to start closing the pool today, but am not sure what to do now about the salt. Several questions:
Any ideas of where the salt came from? Liquid Chlorine?
Can we close the pool without emptying and refilling and deal with it in the spring? We are on a well, and this would be a major undertaking in itself, and to refill and then get the water chemistry right would take some time.
Thanks for any help.
pH = 7.5
Alkalinity = 80
CC = 0
CYA approx. 40
