- Feb 28, 2022
- 36
- Plaster
- Hayward Aqua Rite (T-15)
I'm reading through the Water Balance for SWGs article and it has this statement:
We have been battling high pH and I've been using a lot of acid for that, but they're saying it's just because it's fresh plasture (build completed about 2 months ago).
Basic test strips are showing me around I'm at ~40. The pool store test is telling me I'm at ~55 and no adjustments are necessary.
I now have a TF-Pro Salt test kit, and I'm new with it, but running the CYA test I am filling the entire tube but I can still see the black dot. Maybe I'm not in the best lighting for it..??
It seems that in each of these cases I would need to add some sanitizer to get up to that 70-80 range recommended here.
I have some InTheSwim Stablizer on hand, which I'm hoping is okay to use..?? I believe it is considered Dry Stablizer in the PoolMath app, is that right?
If I enter the current level at 40 it's telling me I should add 4 lbs, 8.0oz. Should I run with that or what would you all recommend based on this info?
Any information on this would be greatly appreciated. Thanks!
EDIT: Additional note, based on what I'm seeing with this TF-Pro test kit (and strips seem to match) I am also low on TA at ~40 and CH at ~200. Again, store hasn't said any adjustments necessary on those. They just keep giving me more muriatic acid to bring the pH down.
Second adjust CYA to between 70 and 80. The biggest mistake that many SWG owners make is NOT having enough CYA in the water! This can create a lot of problems like high acid demand, algae outbreaks, cloudy water, or early cell failure.
