- May 23, 2015
- 25,703
- Plaster
- Pentair Intellichlor IC-60
Does anyone know if the 24VAC power to the CVA needs to be balanced across the three wires -
L1 - 12VAC
COM - 0V
L2 - -12VAC
or does it just have to be 24VAC across the two “hot” leads? I ask because I have some old defunct CVA’s that I’d like to bench test and I have a 3-wire 24VAC plug in power supply that has two hot leads and a ground (not a common). Unfortunately the AC isn’t balanced with respect to ground terminal.
L1 - 12VAC
COM - 0V
L2 - -12VAC
