Sorry for the long post. You can skip the next few paragraphs of background as to how I got in this mess.
I had a contractor do the liner replacement because I figured I would screw it up. Unfortunately, since I am on well water, I also had to have water hauled in but that couldn't be done for a few days after the liner replacement.
So fast forward to today. The liner is installed and the pool is filled to just below the skimmer line. The contractor comes back to cut in the liner only to find that the standard wide mouth skimmer I got to replace the old cracked one won't work. My pool is a Litehouse pool which uses some proprietary (and wider) skimmer called a RapidFlow.
I drive all over Ohio that day trying to find one, and I finally got it. But now I'm not sure when the contractor can come back. Meanwhile the fresh 16,000 gallons of water I ordered is gathering all kinds of debris.
Now here's the problem. This RapidFlow has TWO sets of screw holes. One set that goes through the liner and gaskets to attach the face place, and another set that mount the skimmer to the pool wall and go under the liner -- as in the liner that's already installed and full of water!
Am I screwed? The liner has not been cut yet, but is it possible to detach the top (it's an overlap with coping strips holding it) and get behind it without draining more water? Or should I put the mounting screws through the liner and then just patch over them?
This explains the design of the skimmer: Uh oh
