My pool system was looked at recently, just started owning this inground pool this year/bought the house.
Found out that it’s a salt system with DE filter, built with 2 inch pipes but when the water returns to the pool- the inground pipes were built to taper down to 1.5in and then 1in diameter before it enters pool. Pool guy told me this is why my DE system baseline pressure is about 27psi. Can confirm. I backwash at about 31psi usually. It also scares me because I can’t get near the recommended amount of DE to add to the filter after backwash.
I think this is making it very hard for me to get a clear pool.
Thing has been cloudy for a month despite shocks. It’s balanced, I just can’t get rid of this cloudiness. Pool store recommended clarifier and against flocculent even knowing my system’s uniqueness.
Is this plumbing a problem I should address? Will I accidentally blow up my house if I add clarifier? Should I stick to flocculent for life?
Thanks!
Thanks!
