Hi all - I need to raise my CH level a bit to be in range of my heater's reco (it's at 125 and it recommends 200-400). All other tests are currently in range except for high salt which I need to address.
I was going to add the appropriate Calcium Chloride to raise the level but I thought I had read to first check and fix CSI levels. I have a vinyl SWG pool so I know it is said that CSI doesn't matter for me, but I can't recall why or where I read the relation between CSI and CH and what I need to do first. Can anyone inform me?
Also, I went to check CSI but do not use borates or have test strips for borates - so not sure if I still need do need to test for borates or not considering I do not manually add them (otherwise do I just put zero for borates for CSI calculation?).
EDIT: I just remembered why I was looking into CSI at all. I have been seeing clearish flakes on the surface of my water in direct sunlight and had read that it's likely scale from my SWG. It said that if all else is in range then you probably need to fix/adjust CSI to fix that issue (if that's indeed what it is). I'm not sure if this would be due to a dirty SWG or something, or literally just the CSI itself causing this potential scale.
So in this case, should I then be worrying about CSI despite having vinyl? And if so, should I bother testing borates in order to get proper CSI level? Could the too high salt content be causing the flakes and not CSI (or both)? Salt strips are testing salt at 6300 and SWG wants 3400 - no idea how it got that high, I only added half a bag after the red salt light went on on the SWG a few weeks ago after it rained and I had to drain the pool a few inches.
Thanks.
Thanks.
