Cracked heater manifold
Rick T
118
Houston, TX
So my question remains. Other than low ph levels is there any other reason I would want to install the bypass system? Would it prolong the life of my heater or reduce the pump's workload (enough to make a prolonged difference) because of the internal bypass you are discussing? Thanks.
JamesW
27,718
What is the maximum flow rate that you will have?
JoyfulNoise
Platinum Supporter
May 23, 2015
18,476
Pentair Intellichlor IC-60
Mixing is only regulated when the heater is heating water. There are two spring forces and two flow paths involved. The other spring is on the bypass valve and it takes a good amount of force by hand to push it open (I have a spare). I suspect the forces are balanced such that when the water is flowing to the heater manifold the combination of the spring holding a closed thermal regulator in place is enough to force the bypass valve open. Then, when the thermal regulator opens, the bypass partially closes and most of water flows through the heat exchanger and out through the thermal regulator. With no heat applied, I suspect the flow through the heat exchanger is a tiny trickle at best.
Reactions: JamesW
CaveDiver1932
110
Dallas
In the pictures, the thermal regulator looks mostly closed. It is held in place by a spring, so it probably lets some water pass by pushing the regulator open some.
The purpose of the regulator is to reduce condensation buildup in the combustion chamber.
I‘m wondering if there are small paths within the manifold. Trapping air or stale water seems extreme. If it was sealed, one would think removing the thermostat/ regulator would be part of the winterizing process.
nice pictures and video. Perhaps one of the internals of the manifold exists.
cd
JamesW
27,718
Reactions: CaveDiver1932
Axemaster24!
4
Houston
with all this being said, what is the procedure for protecting the heater during a freeze? I was taught by a YouTube video and one random pool repairman, at a store, to pull the black plug outside and let the water drain. If this isn’t enough to protect then what is?
ajw22
28,568
Northern NJ
You asking about a Pentair MasterTemp heater?
See 3 & 4 below.
CaveDiver1932
110
Dallas
excellent, if I’m seeing correctly,
The left side of the rear section of the manifold has weep holes that drain to the front with one weep hole directly in back of the drain plug.45A6B2D3-96B5-4224-ADCF-199F5A943D97.jpeg0C589625-B765-41B2-8CEB-E18306520D6E.jpeg
I did not see much for right side of the rear section of the manifold. Suspect it will drain to left side.
not sure why they recommend removing the pressure switch other than allowing air to enter the chamber quickly.
cd
CaveDiver1932
110
Dallas
the manual is not so clear. Looking at the above pictures, my opinion is removing the 2” couplings and the drain plug is sufficient for emergencies like in Texas a week or so ago.
One reason the black drain plug might not be sufficient is in an emergency loss of power and air temp below freezing, the small orifice might be clogged with a thin layer of ice and keep the manifold from draining. I’ve seen this happen on pool pumps. When this happens, I have placed a small screwdriver in hot water the gently touch the opening. It normally immediately melts the ice and draining occurs. With an expensive heater, removing the 2” pipes allows air to enter and drain quickly.
this is only my opinion 😉
like:
JamesW
27,718
I think that just removing the drain plug should be sufficient.
It's probably a good idea to crack open the unions just to make sure that all water is drained and them resecure the unions once you have verified that there is no trapped water.
Axemaster24!
4
Houston
like:
Thank you for the clarification, being I’m in the Houston area and this does have me a little worried about another freeze(with no power). I’ll pop the 2” fittings off the inlet & outlet Along with the drain plug. I refuse to suffer through another episode like we had.
mjfrederick
1
Baton Rouge, LA
I found myself in the same predicament as the original poster. Freeze cracked the manifold and the part is on backorder. I finally gave up and decided to try and repair the manifold. I drilled a very small hole at each end of the crack line and gouged out a small channel along the crack on both the inside and outside. I then filled the inside channel with resin, and filled the outside channel with resin and reinforced with fiberglass cloth. Just installed and tested. No leak, and heater is working!B3559F2F-038C-424A-A995-0715D443D325.jpeg57F6D48A-8A45-4805-82A0-46C53DB6EA1F.jpeg
Reactions: richlscott
ppaull
1
Austin, TX
Hey Guys, just a hint if you're still looking for a manifold. I got one off of ebay for a 200K rated heater. I swapped out the back plate of my broken manifold and hooked it back in and it works fine! You might have to also swap out your thermal regulator but other than that the manifold housing are exactly the same!
