Cracked Elbow
Fishy1234
0
362
Apple Valley, CA
The pvc Elbow from pump discharge to the filter cracked. This section of pipe was replaced 6 months ago when the pump casing cracked. I purchased new schedule 40 PVC and various fittings however I noticed the old pvc pipe seems cheap and thin walled compared to the new pvc from home depot. Is there any reason why I should not use the new thicker PVC in this area?
The pump casing cracked 6 months ago, and pentair replaced it under warranty, the pipe from pump was replaced because they stressed it when tightening the flange but causing it to leak at the elbow. Now the elbow has a crack on top. They used white pvc parts and painted them black.
This is the work my neighbor did. He made it a more direct path from pump to filter in order to take some of the weight off of the elbow that was cracked. Now waiting for the glue to heal before testing.
Reactions: markayash
