- Apr 25, 2016
- 78
- Plaster
- Pentair Intellichlor IC-40
Here it is after the fact but I just have to know! I redid some pool plumbing by removing one 3-way diverter valve and installing two 2-way Waterway diverter valves. I used Oatey purple primer and Oatey clear PVC cement. Did I use the wrong cement? I believe the valves are CPVC. I used schedule 40 PVC. There will be no pressure on the pipes for at least 2 weeks but I don’t want the pipes to blow so I will redo if I need to. I am so bummed right now
