I am replacing my Jandy Stealth single speed pump with a new to me Jandy ePump (JEP 1.5). https://www.jandy.com/-/media/zodiac/global/downloads/h/h0311700.pdf
The manual doesn't say how to wire the 2 hots wires L1 & L2 (I do have the green wire to ground on the pump) but there is a label on the side of the pump that says L2-red & L1-black. If I follow this direction, how do I know the red & black wire in the outlet I'll be plugging this into has the same standard, or does it not really matter, ie., you can swap the red & black wire connectors? If it does matter, how do I test which wire in the outlet should be the red one and which one should be the black one?
