Alight, on my way to getting back in balance. Added CYA and might bump FC up a little later. Retested with strips and K-2006. AquaChek 7 strip:
CH: somewhere between 100-250 (hard to tell difference in region of interest)
TC: 4.5 ppm
FC: 3.5 ppm
pH: 7ish (really hard to tell difference in region of interest)
TA: 130ish ppm (a little to tell difference in region of interest)
CYA: 10ish ppm (really hard to tell difference in region of interest)
K-2006:
CH: 100 ppm
FC: 4.5 ppm
pH: 7.6 (easy to tell difference in region of interest)
TA: 145 ppm
CYA: 45 ppm
So my conclusion from comparing the strip to the K-2006, is strips:
CH: sort of close, but hard to tell exactness in the region of interest. may compare again if showing really out of bounds.
pH: useless. won't be using this at all.
FC: in the ballpark and easy to see the difference in region of interest. I'll probably use these for the more often testing, and 2006 for confirmation if getting out of bounds.
TA: in the ballpark. Probably use it for more often testing, and 2006 for confirmation.
CYA: pretty useless and won't use. can't really tell any different in region of interest.
