Correct Order?
It's usually pretty fast, especially the finer grained variety. You will see if it's dissolved when brushing, undissolved salt gets stirred up. Eventually, the salt test will give the final confirmation.
But because of the two-step process that Marty recommended, the process will take some time, so I'd get that started now. By the time the salt is in, and after the first acid addition, your CSI will probably be OKish as long as you don't let pH rise up too far.
