- Mar 20, 2021
- 158
- Plaster
- CircuPool RJ-60
OKay, so we installed the SWG today in preparation and I just balanced all my chemicals. They are as follows:
pH - 7.8
FC - 3ppm
CYA - 60 (up from 25 this morning after adding 3 gallons of conditioner)
TA - 140 (I know this needs to come in, but not my focus right now)
We purchased 800lbs of Diamond Solar Salt today and my tester says I currently have 600ppm salt in my pool (not sure where it came from). My plan is to add the amount the calculator says to get to 3200 and then retest. I’m afraid to overshoot it. Here’s my plan…
Retest pH and chlorine in the morning. Hopefully pH will still be 7.8 and I’ll add whatever amount of chlorine the pool calculator says I need to get up to 6ppm. Then I’ll dump the salt in and brush a few times throughout the day. Then, once dissolved, I’ll fire up the generator at 50%. My pump runs at 2100rpms for 14 hours. I’ll watch and monitor my FC levels for the next week to make sure it’s keeping. Sound like an okay plan?? Anything else I need to do before adding the salt and starting the generator? Thanks!
pH - 7.8
FC - 3ppm
