- Jul 21, 2013
- 65,170
- Plaster
- Pentair Intellichlor IC-60
oh, I didn't know it can be applied vertically.If you want something flexible put Deck-O-Seal in that gap.
thanks
They have a product for vertical surfaces. The HS-1 SL Pool Deck self leveling product for horizontal surfaces. The other one for vertical.
DECK-O-SEAL - Polysulfide-Based Joint Sealant
Seal all cracks and joints with DECK-O-SEAL two-part, elastomeric, polysulfide-based joint sealant. DECK-O-SEAL is used for caulking and sealing joints subject to concrete movement to provide a firm, flexible, weather-tight seal. It is ideal for sealing joints around swimming pools, and for...www.deckoseal.com
There are a lot of cracks in the deck, but some are not clearly visible because deck was painted.you have a flex seal from concrete to coping that should be enough for normal expansion. I dont see any cracks in the deck, when you say its moving what does that mean? theres no easy way to remove the ring or make room around it. either way its gonna look like a patch. I would make a square or diamond cut and remove the concrete and replace with similar pavers so it blends in. that cracking on top of skimmer may not be from pressure just normal expansion and contraction
