I'm probably not alone when I say it's Dang hot right now. Here in southern Alabama we've been in the upper 90s all week, with triple digits 3 days in the next 7 day forecast. My pool is 94 degrees. Now don't get me wrong, when the heat index is 110+ even 94 feels good but I could go for some 87-90 degree action personally.
I think the best/quickest option is the old aerating/evaporation mister fountain setup. I've read @YippeeSkippy's excellent thread (Skippy's New Fountain) which is fantastically helpful, except I don't have a polaris fitting with a quick connect as an option. My pool has three returns, one on the sun shelf and two on the opposite side. I'm thinking the ideal place for such a fountain is on the shelf, it can hopefully help cool the pool but would also be an option to just sit there under the mister. Now, onto my questions.
1. With a normal threaded return, has anyone come up with a way to attach such a fountain with some kind of quick connect? Obviously if I build the whole thing in one piece, I won't be able to thread it on because the pool itself (the 12" deep shelf) will not allow the entire contraption to rotate 360 degrees to thread in place. Plus that just sounds like a headache. I'm thinking something like an elbow that threads into the return fitting, then another set of threads on top of the elbow to thread on the rest of the setup, so installation would be 3 steps - remove return, thread on elbow, thread on rest. Anyone else built one besides Skippy that had to deal with a similar scenario? Haven't had much luck with search yet, but I feel like I've seen others.
2. Now the biggie, I cannot begin to emphasize how much I will stress upon my 8 year old daughter to not grab/touch/pull/hang from the fountain, but it would also be nice to be able to just leave it in for a few days in a row or longer, but I'm curious just how much of a risk it is if she (or a friend) does do just that and gives it a good pull. In my head I envision the worst possible scenario, the fitting breaking off flush with the side of the pool and having to pull up decking to get to the back side for a proper repair. But, maybe I'm overthinking it? Ideally there would I guess be some sort of weak spot in the construction such that any force exerted would snap it off or pop it loose well away from the wall fitting, just trying to visualize what that might look like.
So, any thoughts or ideas or examples you all could share? Thanks!
