OK, so I have ordered a Salt Water Generator (CircuPool RJ-45),
Salt Water Test Kit (Taylor K-1766)
and I bought my salt. (24 - 40# Bags of SureSoft Extra Course Water Softener Salt). I can't find a purity rating anywhere on the bag, I plan to call the manufacturer tomorrow.
I was wondering if it's OK to go ahead and "start" adding salt before I install the SWG... I have 800+ lbs. to add.![Smile :) :)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
Just finished SLAMing my pool for algae. (CC = 0.5; Passed OCLT test; water is clear)
Chemistry
FC: 10.5 (4-6)
pH: 7.4 (7.2 - 7.8)
TA: 120 (60-80 ppm)
CH: 30 (50-300)
CYA: 80 (70-80)
So, my plan is:
1. Add salt 5 bags at a time... less as I get close to target level.
2. Test salinity.
3. Repeat 1&2 until I get to 200-400ppm above recommendation.
4. Install SWG
5. Adjust TA down to recommended level.
6. Adjust CH up to recommended level.
7. Start running SWG and "fiddle" until I get consistent chlorine readings in the recommneded range.
Thanks in advance for looking this over... just want to make sure I'm not missing something.
Chemistry
FC: 10.5 (4-6)
pH: 7.4 (7.2 - 7.8)
TA: 120 (60-80 ppm)
CH: 30 (50-300)
CYA: 80 (70-80)
So, my plan is:
2. Test salinity.
4. Install SWG
