- Jan 20, 2022
- 170
- Vinyl
- Hayward Aqua Rite (T-15)
The SWG is up and running now (turned it on today), but I’ve noticed two odd things:
- The SWG has an instant read function, and it says that the salt level is 3300ppm, which makes sense with how much salt I added. However, I received my Taylor Salt Water test kit today, and ran two tests with the specified reagents, and I got 4200ppm. Which one of these tests is wrong?
- The “No Flow” light is blinking, which would indicate that there’s no water flowing through the pump, but there absolutely is. I think the light may have come on when the Variable Doeed Pump switched over to a lower setting (2200 rpm). Is this common with variable speed pumps? Or is there a setting I could tweak?
