- Sep 28, 2011
- 17
I have an in-ground plaster pool and until recently have been using a Hayward offline chlorine tablet system. I was vaguely aware of CYA and knew it was elevated due to my use of stabilized tablets. About a week ago I did a CYA test using a new Taylor 2006 kit and it was reading in the 150 range. I bit the bullet and drained about 25k gallons from the pool to lower it since the standard 18" draining in the fall wasn't significantly lowering the CYA. I left several feet of water in the deep and a few feet in the spa then refilled. I was surprised that after adding 25k gallons of fresh water that my CYA is still 45-55 or so depending on how my eyes are working with that darn black dot. I decided to leave the CYA problem behind and jump with both feet into the TroubleFreePool and start using liquid bleach/pool shock. I ordered a Stenner 45MP2 but in the meantime I'm using the mobile app to track my testing and add chlorine manually.
I picked up my first liquid shock at a pool supply store. It was an off-brand called Shock It 12.5%. The box had a Julian date of May but when I opened the box at home the containers had a Julian date of late February. I went through 6 of the 8 gallons and bounced between 0-2.5 ppm FC, testing daily. I don't think the advertised 12.5% was still 12.5%. I've moved on to Lowe's Pool Essentials 10% dated May 2020 on the jugs. My FC was 2.5 this morning after using a bit more than a gallon yesterday (FC was 2.5 yesterday morning). It was sunny and hot yesterday and we got .5 inches of rain or so overnight.
The app says my target FC is 7, but adding a gallon give or take each day doesn't seem to be getting me there. There is a toggle button for SLAM in the app, and that recommends adding 5 gallons or so to take me to 22 ppm. Is it recommended to SLAM, then manage the FC on it's way back down? I'll do that if it gets me over the hump and helps me maintain my daily chlorine usage at a more reasonable level.
For reference, my test figures this morning were:
FC 2.5
CC 0
PH 7.6
TA 80
CH 290 (I'm waiting on 40 pounds of calcium chloride to arrive)
CYA 50 ish
CSI -.1
Water temp 81
And the app had me add 153 oz of 10% liquid shock.
Thanks!
FC 2.5
CC 0
PH 7.6
TA 80
CYA 50 ish
CSI -.1
Water temp 81
Thanks!
