Converting from pristine blue to BBB
Michelle W said:
so is that the only thing I need to be worried about at this point, keeping chlorine at schock level until lest comes back at less than 1 ppm?
Yup. Everything else seems to be in range.
And here is to hoping your copper levels are low and that staining does not show up when you go to the higher FC levels.
As long as the water quality continues to improve visibly from day to day, all you need to do is keep the pump running and clean/backwash the filter as needed.
If the water stops improving (even a little) then it is time to look into alternatives.
