I see, so if I'm understanding you correctly the unique plumbing, although has a specific flow rate on a given pump with all factors considered, that flow rate changes when you switch pumps. Even though it may be in the same class of pump and so on.
More or less... at this point anyway.
I actually knew that, but got clouded by the fact that I "assumed" the manufacturers were using some sort of identical standard plumbing setup to test each pump. Hence they could be easily compared with one another because one could "assume" that the plumbing was all the same.
That figures that they wouldn't.... just like so many other things in other industries. Standards, schmandards.
Seeing as I have no clue what I'm doing and I'm still trying to learn, but not fast enough to make a good, educated, non-impulse or misdirected decision on what pump to buy.
Could you be so kind as to weigh in on your thoughts between the Hayward 1hp 2-speed & the Waterway 1hp 2-speed that I have landed on? Or maybe something better, if I have missed it, that's around $200-$230 bones delivered.
I thought the Waterway was better because its pump curve looked better. But I know now that it doesn't matter.
Are they about tomato, tomaat-oh?
As opposed to rebuilding my existing pump, being the cost will be a bit more in the end.
I'm leaning toward the Waterway as it has a 2yr warr (only 3-4mo of season time here) and draws less amperage by a bit on low and a decent bit on high, you know for vacuuming, backwashing, fast filtering from a heavy bather load, etc...
I presume, judging by the amperage ratings, the Waterway is using a 3/4hp motor, as opposed to the Hayward which is inline with the 1hp motor specs @ Century's(AO Smith) site. Does that seem right?
It's the smaller motor I want too, at least that's my understanding. Since you only need a big honker for water features, suction side cleaners and specialty needs. Not for daily filtration & vacuuming/backwashing needs. By the end of the summer or so it'll be going on an approx. 3.7-4.2 SQft filter on my 21,400-22,500 gal pool.
Mind you, I'm not giving up on this topic and throwing my hands up in disgust or anything. Quite the contrary. I still want to learn more about it, finish going through your materials and the like and continue learning. I don't want to become a pump expert, but I'd like to know & at least understand a fair amount about how it all works. At least enough to satisfy my desires to make sense of it all.
Hopefully enough in time for when I design the plumbing for the new pool.
PS. I did mean "putting a smaller impeller on a bigger motor", not "pump". I know the difference, just made a flub up was all. HAHA
I was thinking pump in my head, because I'm talking about the pump overall. My brain forgot to switch to "parts" mode. LOL
Thanks for all your help so far Mark!
