Convert from Perma Salt System
Jun 23, 2019
10
Lincoln Nebraska
We have a 15x26 above ground local pool. We have teenagers and our house is a gathering of teenagers. Last night I noticed our Perma Salt System controller wasn’t displaying anything and was plugged in next to pump and pump was working. My wife and I were reading on your sight and I think we are going to go back to using chlorine. One concern using the Perma Salt System last year was green colored hair. I will be posting more questions as we start the transition today
Richard320
23,677
San Dimas, CA (LA County)
Welcome! :wave:
I think permasalt is part saltwater chlorine generator and part metal ionizer. If you've already got all that salt in the water, it would be a shame not to replace the unit with a plain saltwater chlorine generator. With a bunch of teenagers, splashout will reduce the amount of residual metal in the water.
While you're deciding, you should use bleach.
We're here to help.
Donldson
4,432
NW Ohio
Welcome to TFP!
While you can just start using chlorine in your water, if you have been using Permasalt for the entire time you have had your pool it might be a good idea to replace some water and try to get your copper level down first.
If you switched to Permasalt because of unpleasant experiences with chlorine pools before, I encourage you to check out the ebook Marty linked to above. TFPC pools are managed a lot differently than traditional chlorine pools and feel, clarity, and ease of managing the water is unrivaled.
Jun 23, 2019
10
Lincoln Nebraska
Thanks- I think we are going to avoid the salt because we have been reading it will corrode the metal railings. My question is the we have had several inches of rain the past few days - would that be enough to reduce the metal?
Richard320
23,677
Any rainwater dilution will reduce the metal content in the pool. A couple inches is only a couple percent of the water, so the reduction will not be very significant.
Jun 23, 2019
10
Lincoln Nebraska
Next Question. While I am waiting for my test kit. I need to add chemicals. The usual routine is chemicals for the ionizer. Then some Algeicide and then 2lbs of shock. So I will assume low chlorine- how much bleach should I use to get by until the test kit comes?
mknauss
29,982
Laughlin, NV
While you are waiting on your test kit, add 5 ppm FC worth of liquid chlorine / plain bleach to your pool each evening with the pump running.
