Yes, water was clear, zero CC and no chlorine drop overnight....and, my current chlorine levels are WAY above even SLAM. I am sitting at 55 CYA and 31 FC (down from 35 yesterday).To confirm, you say you SLAM'd, but did you actually follow the SLAM Process through its entirety passing all 3 criteria BEFORE moving on to the Mustard elevation?
Thanks, I have vacuumed it to waste a couple times and it keeps coming back...I'll keep it up and see if It eventually stopsI agree with Tx,
A. That's not yellow algae, B. Vacuum whatever it is off the floor.
I couldn't tell you what that is down there other than maybe carbon, mixed with dirt is my best guess with those chlorine levels. It Dang sure can't be algae though.
