- Jun 24, 2021
- 17,073
- Vinyl
- CircuPool RJ-60 Plus
RJ-45 is rated at 1.9lb/day. (Use that number in Pool Math). Running Pool math, I get it will raise FC by 4.4. In real life, I have found that even though it is rated that way, running 100% doesn't quite work out that way. You may find you have to run longer to actually get 4.4.Ok thanks! I currently run my pump 4 hours a day (it's not vs) would that be enough to raise my FC by 4 in the summer if I got say a rj-45 (in tried using the add chemical calculator but didn't understand it)
