I am replacing an older Tristar VS pump with a new model. It is the secondary pump to circulate an infinity edge trough. The old pump was only wired to the Aqua Plus using Aux2 and had DIP switches 1 and 2 on. The main pump is a new Tristar VS 2.7 HP connected to the Aqua Plus with the new three wire terminal block and is working fine.
I replaced the internal terminal block and wired the new terminal block to the pump and the Aqua Plus just like the main pump. I turned on DIP switch 2 per the quick reference guide. The pump has power but is not starting when the Aux2 button is pressed. What did I do wrong?
