New neighbors moved in next door and they have a pool. He's had some algae develop and I tested the water for him using my TF-100. I went to perform a TA test, but the solution never turned blue/green when adding the R-0008. It instead turned a deep pink.
The other readings were awful, and I'm not sure if that throws off the TA test somehow or if TA is SO low, that the test can't be run?
FC: 0
CC: 0
pH - under 6.8, no idea how low
TA: no idea, that's why I'm writing this post
CYA: ~50
Vinyl pool, supposedly 25k gal., sand filter.
I'm having him raise the pH with soda ash, then start the SLAM process with 12.5% sodium hypochlorite. I have no idea what the TA test result means though, so I can't offer any advice. So now I look to the experts.
FC: 0
CC: 0
CYA: ~50
