- Jul 3, 2013
- 9,028
- Vinyl
- CircuPool SJ-40
hey there, welcome back
With the heat and sun it will use your FC.. I have mine running 12 hours now.. you may need to do the same and run 6 in the morning and 6 at night..
You are correct, CYA will not evaporate or leave unless you backwash a bunch or overflow... but, CYA of 50 or 40 will look really close depending on the sun, how bright it is and how many times you pour back and forth to see the level..
You really need to get it to CYA 70, then running 12 hours you should be good to go..
ohhh ya, the PH will continue to rise until your TA gets lowered, every time you lower PH your TA will lower a little.. each time you will go longer before needing to add MA
