- Jun 21, 2020
- 762
- Fiberglass
- Jandy Aquapure 1400
My pool (Leisure Fiberglass) recommends calcium hardness between 80-120ppm but Raypak heater recommends between 200-300ppm. I noticed the anode rod for the heater has worn pretty quickly from installation last Sept and this season. I understand low calcium makes the water corrosive and my level is 75ppm so I am about to go get the Clorox hardener and was going to bring up to 120ppm but I don't want to wear out my heater if the mfg recommend minimum 200ppm for fiberglass pools. Which one to follow. My PH is 7.7 and my TA is 70. Which should I follow pool mfg level or heater levels if I follow heater is higher calcium ppm going to damage the fiberglass/gel coat surface??
