Confer A frame ladder is an algea farm - will drilling more holes hurt/help?
WagonQueen
Active member
Jun 29, 2014
35
Pittsburgh pa
We have a confer A frame ladder with the raisable, lockable steps. The steps have two holes on top - so water get in but doesn't flow. It also doesn't come back out when removed from the pool at the end of the season. We just completely took the ladder apart and have been soaking in bleach water to try to clean it. (We are just getting a pool up for this year but have had the ladder for 6 years now)
It's also SO hard to get out of the pool at the end of the season since it won't drain.
Has anyone drilled extra holes to allow for better flow and drying at the end of the season? I can't understand why they would design a pool ladder this way. I keep reading it's not the ladder, it's your water - but I don't know how much the water chemistry matters when the water can't circulate.
I'm considering replacing it with a vinylworks ladder that doesn't trap water the same way but the reviews on that are pretty hit or miss.
bloodfromastone
120
Buffalo, NY
I bought ours used and it was an algae farm, too. I just put the hose into every hole on high-stream, turned it on each side and blasted it out. When we took it out of our pool last summer, we didn't have the same problem again.
HeidiP
111
Ottawa/ON, Canada
Smart, good reminder for me I will use the turkey baster bleach option because I left my ladder in over the winter... Ugh. And got algae in the spring... Dun dun dun!!! Baster sounds like an easy fix.
