For example, if the pool is 1 million gallons and the required turnover is 8 hours, then your minimum flow rate is 125,000 gallons per hour or 2,085 GPM.
Each skimmer is rated for maximum flow and the main drains are also rated for maximum flow, so you have to know these numbers as well.
Sizing commercial equipment is complicated and you have to do all of the calculations correctly.
You can’t just use “Rule-of-Thumb” to guess if a certain horsepower will be right for a certain weight of sand.
So, you can’t ask if a 2.7 HP pump is right for a 600 lb sand filter because it does not work like that.
This shows the performance of the SP32950VSP which is the 2.7 HP Tristar VS pump.
It can exceed 175 GPM, but only at low head loss.
If we graph 3 possible system curves on the pump performance curve, we can estimate the flow at any speed.
To develop a system curve, you need to know the total head loss and flow at different speeds.
However, we need to know the pool volume and required turnover to calculate the required flow rate.
