Hey everyone. I am looking for a little help with one of my diverter valves.
My return diverter valve for the pool/spa has started leaking in the spa position. Returning water to the pool with a pressure of 12PSi the valve is fine. If I switch to spa and the valve rotates to run water back to the spa it starts leaking heavily. The pressure at the filter reads 30PSI when in spa/jacuzzi mode. It appears it's leaking out of the top.
Should I only replace the little O-Rings or the entire diverter?
Thanks for the help!
