- Jan 4, 2022
- 27
- Plaster
- Saline Generating Systems Breeze 540
I am about to install the Pentair 521107 Easytouch upgrade for my current Compool LX3800 system. I was wondering if any of the experts or those experienced with this upgrade have come into this.
Thank you in advance for any help!
- Sigle Body System:
- First of all, when I reviewed the installation instructions, the first thing I see is that it talks about the "Single Body Sytem". I'm assuming I leave it as is from the factory given that I have both a Pool and Spa and therefore have what I would consider a "Dual Body System".
- RJ12 Cable and Port
- My current Compool system has the old CP3800 Indoor Control Panel which is connected to my LX3800 utilizing an RJ12 Cable.
- Reviewing the installation instructions, I see that the new Easytouch system has two connection points for a control panel, the "J20" connection point and the COM connecting point.
- The kit also comes with an RJ12 adapter.
- Now I'm wondering if I should be utilizing the RJ12 adapter connected the the "J20" connection point to my origianl RJ12 cable, which would then run into the house and then connect that to the 520549 Control Panel.
- Note that the 520549 Control panel only has the ability to connect with invididual wires which my next assumition would be that I would have to cut the RJ12 connector off the end and then utilize those wires.
- Intelliflo VS Pump
- I have also upgraded to an intelliglo VS Pump for my main filtering pump, I understand that for this pump, it will be wired directly to the breaker, however, for the control wire, 350122, where on the easytouch upgrade board do the wires go?
- Superflo VS Pump
- I decided to go all out and also upgrade my waterfall pump to the Penatir Superflo pump. From what I have seen, for this pump, I wire it once again directly to the breaker, but then the control wires will get wired to relays, I'm fairly confident in this scheme, just figured since I was asking multiple questions I would throw this one in there.
