Complete with Refill Am I ready to SLAM?
Just a suggestion but you might want to use PhotoBucket to share pictures. I'm not seeing any of the attached pictures. TFP's attachment space is very limited. Photo bucket works a lot better.
Sent from my iPhone using Tapatalk,16k gal SWG pool (All Pentair), QuadDE100 Filter, Taylor K-2006
FC still dropping about 4-5 ppm every 12 hrs. Conntinuing to brush & vac. filter cleaning is reducing & clarity is improving, I can see the drain even after brushing.
Did you pull the lights out of niches, open up and umbrella sleeves and remove any ladders? Algae likes to hide in those spots.
Seeing very little CC, maybe .5. The color change is extremely slight for that test.
I failed to pull the light and clean behind that & the water is a little chilly to go diving so I will have wait that one out & hope for the best. All of my ladder connectons are on deck. Everything below the water line is plaster except the light & plumbing. I have been giving extra scrubbing attention to the steps and the tile line.
I am finally getting optimistic.... I had no idea that the previous owner left the pool in such bad shape. Based on the amount of plaster granules I have filtered out I can assume that pool has not been aggressively brushed in several years. I have never owned a pool before & I was naive in assuming because he had a 'contract with the pool store' that everything was fine. Live & learn, die & forget it all.
Not sure how chilly your water is, or how far down your lights are... I can lay on the deck and unscrew the light housing from there. Maybe you could try the same. Then a brand-new toilet brush to at least get the worst of it out until it gets warmer? My lights love to grow algae!
Out of town this week, my wife is keeping an eye on the FC levels & brushing. I will attempt to hang over the side and clean the light this weekend
Ordered a barracuda G3 over the weekend. Wife got it assembled and installed late this morning. Has had to clean the filter 3 times since. Mostly plaster sand. Looks like this thing will help me get this stuff out of the water.
Still losing about 5 ppm FC every 12 hrs, clarity is improving.
My wife reports that the frequent filter plugging continues now that the Barracuda is running constantly. It appears that I was stirring the stuff up when I brushed only to have it settle back to the bottom. I brushed as much as possible toward the drain but apparently was not very effective. I definitely had a lot more sandy debris in the pool than originally thought :evil:. She is keeping up with the brushing and the FC levels. Hopefully we will be much closer to clear water when I get back this weekend.
