Communication between Intellichlor and Intellicenter
I have an Easytouch so I guess Screenlogic is different.
Why not just disconnect the Intellichem from the Intellicenter? It is a RS485 connection. .
Is your pH an issue? Most folks find it is not a big deal. And with a vinyl liner, you have a lot of leeway on pH and TA.
Have you looked at your Intellicenter Manual? It shows on page 79 how to select/deselect the Intellichem.
Or, just disconnect the RS485 wires from the Intellichem to the Intellicenter. Be sure to power everything off when you do that.
Thanks yes i did de-select the Intellichem and that causes the SWG to BLINK all % at the bottom. That is why i was hoping to get to step 2. Let me play with it tomorrow and see if i can figure this out. Thanks again!
I suspect you need to just remove the Intellichem entirely.
I would not think pH is a big deal in your area. Your fill water is not high in TA is it?
