Well I went through every screen on my system and this set up is not there so I am guessing my new IntelliCenter and set up is different. I looked through the Pentair info and no help either. SorryThank you let me give this a try!
I wonder if I am missing somethingWell I went through every screen on my system and this set up is not there so I am guessing my new IntelliCenter and set up is different. I looked through the Pentair info and no help either. Sorry
Ya might have to. I was hoping to keep the acid pump as the PH is close enoughI have an Easytouch so I guess Screenlogic is different.
Why not just disconnect the Intellichem from the Intellicenter? It is a RS485 connection. .
Also the SWG is using that so I would have to just that the intellichlor out of the system and rewireYa might have to. I was hoping to keep the acid pump as the PH is close enough
I been playing with the ORP level to see if I can get it to get close and keep the SWG at 8 ishAlso the SWG is using that so I would have to just that the intellichlor out of the system and rewire
YesYour intellichlor is hooked to the Intellicenter directly is it not?
But when I turned off the intelichlor breaker it turns off the SWG
I will have to look closer at the wiring tomorrow. The electrician wired it upBut when I turned off the intelichlor breaker it turns off the SWG
Always appreciate your input so helpfulI will have to look closer at the wiring tomorrow. The electrician wired it up
Thanks might just do that! fill water is goodI suspect you need to just remove the Intellichem entirely.
I would not think pH is a big deal in your area. Your fill water is not high in TA is it?
