Just an observation ... you keep on looking for shortcuts.
Our methods are based on science and chemistry. If you follow the process you get the expected result. When you shortcut the process you can end up where you did not expect. If we had a proven way to clear up a pool in one shot we would be sharing it with you.
Add 10 ppm of CL and then test after 30 minutes. Repeat until you can hold at least 5 ppm after the 30 minutes. Once there you can being the
SLAM Process. Follow it step by step with no shortcuts for best results.
