So..
Went away on vacation for a couple of days. Before leaving, pool was balanced, added some extra chlorine and algaecide just in case. Had been fighting what I thought was pollen collecting on the floor since opening in May.
Came home to a yellow pool with a ton of algae in the floor. Started shocking, added more algaecide, vacuumed to waste, brushed. Repeated multiple times per day. Cya might have been high 50s, so using pool math I added appropriate amount for SLAM. Also added phosphate remover. Hit it with oxidizer later in the week.
6 days later and another dose of algaecide, pool is finally clear (can see the deep end floor clearly). Still see a few small patches of yellow on the floor near the returns. Vacuum them to waste immediately. Assumed the filter can't capture the tiny yellow algae, so used floc one day, clarifier the next. Added some DE to my zeolite filter too.
Kept FC high 16-20 and finally got CC to 0 this morning. FC dropped to 6, so I added a little chlorine to boost.
Checked tonight and FC dropped to 4 and CC now at 0.8.
I've had high FC for almost 8 days now. Gone through many many gallons and bags. What am I missing? All other chemicals are balanced (ph, alkaline, cya dropped to 40s with all the water I had to replace). Been flushing filter regularly as well. Seems as soon as I let fc get tov slightly higher than normal levels, CC starts to run away.
27k gal inground vinyl liner pool. New liner last season.
Replaced zeolite this season
