this is my second summer running my CMP powerclean ultra SWG and in the past I would run it at 25% and it would stay about 3-5ppm, 50% or higher and it would be 7ppm higher even in the middle of the summer heat in Arizona. In the past week as the temps have come up (pool temp about 74 max during the day and air temps mid 90's) I"m barely getting 2ppm after the unit has run for 8 hours at 100%. I am going to do an overnight chlorine loss test but I have never had algae in the pool and have kept it very clean and the swimmer load is one person. I have cleaned the cell itself when there was actual buildup but for the most part there really wasn't much at all and I only used the plastic stick that the manufacturer provided, I never used acid.
The CYA is at 30 and I know it should be raised a bit but I'm testing first thing in the morning after the pump shuts off and before there is any sunlight on the pool. Salt level was measured at 4500 by two differen't meters and CMP recommended range for this cell is 4000-4500. I did do a Chlorine check at the return when the pump is running high speed and it was 5ppm at 100%.
Any ideas on if this is a sign that the cell is failing? The unit hasn't been in operation 2 years quite yet.
