Everything is on one variable speed pump. Waterfall does not function at the same speed it did. Skimmers don't seem to be doing a great job at skimming. I checked as far as a could to see if a line was clogged. Pulsed them. Checked the salt cell for a clog. Checked the pump for a clog. Took the valves apart to see if there were any clogs... No luck at all. Even cleaned filters again. Water quality seems ok but lots of floatsom.
I switched from GPM to RPM as advised so not exactly sure where things went awry.
Salt cell starts working around 2000rpm.
Waterfall doesn't kick in till around 3000rpm... Used to function at a lower rpms.
The highest speed doesn't move the water like it did.....
GPM 40 RPM 3450 1862W Stat Normal Filter 27 PSI
GPM 37 RPM 3000 1284W Stat Normal Filter 27 PSI
GPM 29 RPM 2500 7482W Stat Normal Filter 27 PSI
GPM 23 RPM 2000 394W Stat Normal Filter 27 PSI
The way they put the lines together I don't seem to be able to get a bladder in to blast water the other way through the lines. I suppose this is built this way to get objects throught the lines.
I tried to provide as much data as possible. Maybe some is irrevalent but I am curently clueless enough not to know what is relavent.
If there is a how to document please point me to it. Any advice greatly appreciated. I'll try everything I can before bringing in a pro...
