I had to replace my cell after about 28 months. The manufacturer sent me one for free.I had been following Jandy's suggested 10% acid bath cell cleaning procedures to rid the cell of calcium buildup. I maintain my pool meticulously and stay within TFP suggested ranges. The CH ranges 375 - 425. Currently 375. Lately I noticed the expected effectiveness of the cell dropping off and I knew the calcium buildup was substantial due to the clear plexiglass enclosure.
A friend of mine suggested using CLR as a gentler cleaner. I have to say it did an excellent job, but it took much much longer. The plates looked different than when I'm done doing it with muriatic acid. I started at 3 in the afternoon with 2 ounces or about a 15 % solution and ended up adding another 2 ounces 6 hours later. When I awoke in the morning the cell and diodes were clean as a whistle. My cell is working as efficiently as it did on day one. I asked the manufacturer if this method might not prolong the life of the cells. They had no comment and said they could only say to use muriatic acid.
One could not realistically expect your typical pool tech to do this. I wonder if the instructions using muriatic acid are to accommodate the pool techs who are pressed on time.
Any comments from the chemists, metallurgists and other such learned members?
