Cloudy water
dlm80
2
Washington Pennsylvania
Fiberglass
Intermatic I-Pure PE25k
Help!! I’ve been fighting a cloudy pool for weeks. Tested water yesterday. Noticing possible old algae on walls deep in the water. I have 24 ft round pool, 52in walls, sand filter.
Welcome to TFP!!!!
How are you testing your water?
Here are our recommended kits. Link-->Test Kits Compared
With a CYA of 200, it isn't possible to maintain enough sanitizing HOCl to keep algae at bay.
How did you determine a CYA of 200?
The directions don't have a way to measure 200.
Do the diluted CYA test...
repeat the test adjusting the procedure as follows:
  1. Fill the mixing bottle to the lower mark (15 ml line) with pool water.
  2. Continue filling the mixing bottle to the upper mark (30 ml line) with tap water.
  3. Shake briefly to mix.
  4. Pour off half of the contents of the mixing bottle, so it is again filled to the lower mark (15 ml line).
  5. Continue the test normally from adding R-0013, but multiply the final result by two.
If you need to dilute the pool water further, to get a test result below 90, then apply these ratios:
Pool waterTap or distilled waterMultiply result by
112
123
145
