I would look into doing an drain exchange -
www.troublefreepool.com
It takes a really long time, even at SLAM levels for the sulfamate ion to break down. It has to undergo hydrolysis of a fairly stable covalent bond within the sulfamate molecule and that usually only happens at a pH that is dangerous for people and pools. This is why draining is needed unless you’re willing to chew up weeks worth of pool time.
I meant to keep and track total chlorine since that’s the only reasonable way to deal with this. I would make sure that your TC is at least 10% of CYA and hope that it’s enough to keep away any algae. Keep the SWG running at whatever output is needed to maintain a 10% TC/CYA ratio. Consider doing a no drain exchange to speed up the process of getting back to normal.
